dot com error when trying to upgrade firmware
I'm getting a .com error when trying to check for new firmware. I've currently got 4.16 and know that 4.17 is there but keep getting this error. Anyone have an idea what this could be?
travispape
- Site Admin
Re: dot com error when trying to upgrade firmware
I don't recognize that error message, do you mean "Server not available right now. (Com error)"? Make sure your internet service is working and make sure that you don't have any firewalls blocking iBike.jparker wrote:I'm getting a .com error when trying to check for new firmware. I've currently got 4.16 and know that 4.17 is there but keep getting this error. Anyone have an idea what this could be?
Yes it is the server not avalible error-sorry for not putting that in. Is it a firewall issue?
travispape
- Site Admin
It could be. If you have a firewall that blocks iBike from having Internet access, it would cause that error message. You would also see the message if the computer does not have Internet access; however, if you are reading this on the same computer with the error message, that is obviously not the problem.jparker wrote:Yes it is the server not avalible error-sorry for not putting that in. Is it a firewall issue?
I'm guessing it's a firewall because everything else is working fine. It's a new computer with Windows 7 and I've loaded everything for iBike opertion into it and everything works except getting new updates from the web. I'm not sure how to disable a firewall, I know just enough about a computer to be dangerous so I probably need a little coaching on this one
Thanks any help
travispape
- Site Admin
I sent you an email yesterday, but maybe isn't a good address for you. Let me know if you are still having trouble: tpape@velocomp.comjparker wrote:I'm guessing it's a firewall because everything else is working fine. It's a new computer with Windows 7 and I've loaded everything for iBike opertion into it and everything works except getting new updates from the web. I'm not sure how to disable a firewall, I know just enough about a computer to be dangerous so I probably need a little coaching on this oneThanks any help
travispape
- Site Admin
Ok, I talked to the customer and we figured out the problem is that the proxy server checkbox was checked. For most home networks, this should be unchecked.
Travis
Travis
I just wanted to thank Travis again for taking the time to call me and work through this issue
and as I told Travis last night that their customer service was by far the best that I had ever delt with and that I was really impressed with the ibike computer,software,updates on the firmware,warranty etc...
:!:Thanks again and keep up the great work
Jeff
