Two profiles
philatlondon
Two profiles
Post by philatlondon »
Can I send two profiles to Gen III from ibike 3? If so, how I do stop the second one over-writing the first. If I can, how do I know which is which when I switch between profiles on the unit?
Re: Two profiles
Yes, you can upload two different profiles to your Gen III. Here's how to do it:
1) Enter Setup on your iBike. Go to Set Prof.
2) Click the center button. Use the up/down arrow to select the profile number where you want to transfer information from iBike 3 into your iBike. Click the center button to accept.
3) In the iBike 3 software, go to Profiles/Send Profile to iBike. Select the profile you want to transfer to your iBike, then click the Send to iBike button. Your profile will be transferred to the profile number you selected in step 2.
4) Enter Setup on your iBike. Go to Set Prof.
5) Click the center button. Use the up/down arrow to select the OTHER profile number. Click the center button to accept your choice.
6) In the iBike 3 software, go to Profiles/Send Profile to iBike. Select the profile you want to transfer to your iBike, then click the Send to iBike button. Your profile will be transferred to the OTHER profile number you selected in step 5.
