two rides in same day confuse Tracker overlay
wjwlitespeed
Post by wjwlitespeed »
If I have two rides on the same day (commute back and forth to work) but only use the Tracker app for the second (longer) ride. When the rides are imported into Isaac, the Tracker data gets attached to both rides and the morning ride start time incorrectly gets overwritten. I know that I can manually correct the start time for my AM ride but is there a way to stop this from happening? Can I detach the Tracker data from the AM ride? Thanks
Re: two rides in same day confuse Tracker overlay
Hmm...do the following:
1) Download again your AM ride.
2) You should see a pop-up window appear asking you if you want to override the start time. This window appears because there is not a Tracker file for it, but Isaac finds your PM Tracker data might be a fit
3) Do not override the ride time.
After you do this your AM ride should appear, without any associated tracker data.
