Can't get to "CAL RIDE" screen
quoc
Post by quoc »
Hi...another newbie question but I've done 3 coast downs and now I'm at the point of doing a Calibration Ride...except I can't find the screen that says CAL RIDE.
I have a Gen II iPro. Is there a secret button I need to push?
wellmt
Re: Can't get to "CAL RIDE" screen
Post by wellmt »
There isn't one on GenII. You just do a 4 mile out and back ride after your coastdowns. Then select that when you get back to download the coast-downs/cal ride from the menu.
R Mc
Post by R Mc »
Add to wellmt: to make it easier for ibike3 to find that 4 mile ride--do a trip reset at the beginning and end of it . . .
And another thought - 4 miles (2 out, 2 back) is a minimum - if you can go further, then do it - more data, better analysis - with the caution that a significant weather change during the ride might lead to anomalies.
wellmt
Post by wellmt »
Good point. Also I'd recommend doing more than 3 coastdowns. Half a dozen would be good, a dozen is even better! Also I'd say do your coastdowns and then do the cal ride right away, so the conditions are the same.
quoc
Post by quoc »
Well that explains it...I thought I was losing my mind. Thanks for the quick responses.
