analyze route
still-chasing
analyze route
What's your opinion on "Automatically analyze route" on the "preference" menu? The reason I ask is because comparing the original download to corrected, the tilt is off (in the analyzed) especially in the beginning of the ride.
Re: analyze route
The iBike gen 4 analysis tilt during the first five minutes in a special way, to correct for an incorrect tilt cal or tilt correction.
So the first five minutes, when they are a significant mismatch, indicates the need to do a careful tilt cal before your ride and or redo your cal ride.
Regards,
Regards,
still-chasing
Re: analyze route
Thanks. Do you set your preference to "Automatically analyze route"?
Re: analyze route
I do not. I think that all has been improved so someone using the auto analyze route setting may want to speak up for it. I used to first save the ride file immediately with _raw in the name and save it again without so I could easily fall back but that doesn't still seem needed. The software has come a long way
I do not because I like to see the before and after numbers. Gives me a better feel for what is going on, as I get into understanding it, that is.
