Adjust ride file for wrong weight after ride?
mutschi
Post by mutschi »
When it is cold the ibike aero seems to do strange things sometimes. In my last ride I noticed that the power readings uphill were way too low and downhill way too high. After I downloaded the ride I noticed thr reason: I had 11 kg's as total weight instead of the usual 81.7 kg's. However, I can't fix the problem. When I go to "Tools" and "Analyze ibike Settings" I can put in the new weight. But after I enter and the ride gets re-calculated it is still way wrong. This time the power readings are just crazy high e.g NP 555 and max power of 3300 Watts. Any ideas how to fix it?
Re: Adjust ride file for wrong weight after ride?
Please post your ride file. I may be that your battery voltage was too low, but we will see.
mutschi
Post by mutschi »
thanks for your fast reply. Attached my file. Yes, I think the battery was low. We getting into winter here in New Zealand and I started the ride with 11 Degrees. Used ibike for almost a year now and it worked very well over the summer. Thanks for looking at my file.
Patoga return_05_30_2012_1038_87_km.csv
(2.79 MiB) Downloaded 384 times
Something is goofy with your ride file. Our expert Travis will take a look!
