Mac and iAero Won't Speak to Each Other
chrispy
Post by chrispy »
I have an iAero (FW 1.30) and the 2.0.7 iBike2Mac application, with the latest USB driver installed, on a G4 PowerBook running OS X Leopard, 10.5.3.
I cannot get the Mac to talk to the iAero, no way, no how. The adapter is plugged directly into the USB port, the iAero is mounted and turned on, and I get no love.
I have some ride data to slurp off, prior to flashing to FW 1.31, but I can't even get that far. :-(
Help wanted!
Chris
chrispy
Re: Mac and iAero Won't Speak to Each Other
Post by chrispy »
I solved this problem accidentally, just now. I connected to the VPN at work, and got a dialog about a new network interface--the iAero's USB-to-serial adapter. I set up a null configuration for it in Network Preferences, and now the iAero works.
I guess the USB driver does not auto-load.
chrispy
Post by chrispy »
And now we're back to not working again.
I'm growing steadily more and more frustrated.
I am a life-long Mac user and I've been using my Mac with the iBike software since release 1.0.0 and with every release since then. No problems at any times.
I don't, however, use my Mac with a VPN.
Having answered hundreds of Windows tech support calls, I can tell you that they outnumber the Mac calls 99 to 1.
Please email me off-line and I'll put you in touch with the folks at Silicon Labs (the owners of the driver software). Perhaps they can figure out what is going on.
jhamann@velocomp.com
chrispy
Post by chrispy »
Well, I'm still stuck in limbo-land. Every once in awhile, my PowerBook will speak with my iAero, but most of the time, it won't.
(PowerBook G4, 1.67GHz, 2GB RAM, OS X Leopard, 10.5.4).
To see if it was just something goofy with that machine, I installed the USB drivers and the iBike software on the Intel-based iMac. Still no joy.
(20" iMac, Core2Duo, 2.16GHz, 3GB RAM, OS X Leopard, 10.5.4).
Of note, I seem to have had my spate of trouble with opening the iAero ever since upgrading to 10.5.3. I wonder if the SILabs driver needs some porting work for 10.5.3 and onward?
John, I can appreciate that Macs tend to be a lot less trouble than Windows machines. That's one major reason that I own Macs (the other being that I'm a dyed-in-the-wool UNIX guy). Nonetheless, I'm having problems. Travis has been helpful, but he's a busy guy.
I'd love to get to the bottom of this. As a point of interest, I dtruss'd iBike2Mac to see what was going on, and every syscall to the SLABtoUART driver succeeded, yet the app still spat out the "iBike is not responding" dialog. I sent the output to Travis.
I'm puzzled. Is there anyone else out there trying to use an iAero with a Mac that is running Leopard 10.5.3 or 10.5.4?
I am. On 5 separate machines.
Perhaps your USB adapter is intermittent. Send me an email and we will send you a replacement USB adapter.
chrispy
Post by chrispy »
The replacement cable solved the "can't talk to the iAero" problem.
I am very, very pleased with the way you stand behind your product!
