Elevation bug with iOS 5
We are aware of a bug that causes elevation to not work properly with iOS 5 and the iBike app.
This affects iBike Dash + Power units only...
We will fix this bug as quickly as possible.
Re: Elevation bug with iOS 5
Bug has been found and squashed. App update coming as soon as Apple releases it...
Jfala
Post by Jfala »
John,
Thank you. Does the elevation bug affect Power readings as well? The power readings ever since I have upgraded the firmware and to iOS 5 have been all over the place. This morning I noticed that when I was sprinting in an area where I would normally show between 400 - 500 watts my Dash was showing in the 130s. Took about 20 minutes into the ride for the power to "settle" in.
Jeff
Yes, unfortunately.
We will be submitting the app this evening.
Jfala
Post by Jfala »
Thank you.
