Hello, is supposed to appear a bar graph and a number on the right on the power screen. In my Newton It doesn´t happen. Is there any mistake about the settings?
What does that bar and the number mean?
Thank you
BAR GRAPH DOES NOT APPEAR
Re: BAR GRAPH DOES NOT APPEAR
The bar graph is the power bar with the scale number to the right. You can turn it on or off in Settings > Racr Menu > PbAr.
The power bar is an instantaneous graph of the current power output. This would be the equivalent of setting smoothing to zero. As the power bar gets almost full it will shift from 2 to 4 to 8, etc. So... a half full power bar with the number at 8 means you're producing 400 watts at that moment.
OK ,thank you very much
