Newton broadcasting to Ambit 2S
cghebert
Post by cghebert »
Hi all,
I recently upgraded to the 5.0 firmware and had a quick question regarding pairing with another ANT+ computer, specifically a Suunto Ambit 2S. I read in the manual that with the Firmware 5.0 the Newton should automatically broadcast the power data, but I haven't been able to successfully pair it with my Ambit.
Is there something I need to enable in the Newton or Isaac setup to turn on this feature?
Is there anyone out there using a Newton and Ambit 2S successfully together?
Any help is appreciated.
Colin
Re: Newton broadcasting to Ambit 2S
Do a Scan with your Newton; this will cause the power out function to be enabled on your Newton. Then, pair to the Suunto.
cghebert
Post by cghebert »
Worked like a charm, thanks for the speedy response!
