I saw a thread with a graphic of the repair screen of tilt/power. It has an additional grey 'high vibration' marker.
Is this only in association with Gen II?
I have the original ibike pro with the latest software from the site and my tilt/power repair screen does not have that facility of high vibration
high Vibration software analysis
Re: high Vibration software analysis
The high vibration sections of a ride show up automatically on the advanced analysis screen. I was running the original iBike and the feature worked, so maybe you just haven't been getting any vibation problems to report.
philatlondon wrote:The high vibration sections of a ride show up automatically on the advanced analysis screen. I was running the original iBike and the feature worked, so maybe you just haven't been getting any vibation problems to report.
hmm, would doubt that, I often on rapid descents still get some high power numbers when the accelerometer is overwhelmed.
Also - as i set out yesterday a road a couple of miles from me is in the process of being re-surfaced, they have taken off all the smooth tarmac and left a very rough gravelly surface. I was getting power readings of 600 - 800 watts when freewheeling at 15 - 18 mph. A definate candidate for the high vibration.
- Site Admin
Ben,benlane wrote:I saw a thread with a graphic of the repair screen of tilt/power. It has an additional grey 'high vibration' marker.
I just wanted to be sure that you are aware that the correction for high vibration is available for all units, primarily the original unit like you have. (Vibration correction is rarely needed, if ever, for iAero or Gen II.) On the main window, click the "detailed" tab. Press the "Analyze Tilt & Power..." button, and then press the "Advanced..." button to see any sections of the ride that are corrected for high vibration.
Note that the same correction is made if you use the "Auto Analyze" button in the Quick tab.
Travis
