Getting TrainingPeaks/WKO to use DFPM power
kylef
Post by kylef »
Is there a way to get power numbers from a DFPM to appear in Training Peaks instead of the ibike power numbers? The default appears to be that Training Peaks uses the ibike power.
Also, I seem to be getting some "spikey" data from my SRM. I don't know if this is an SRM issue or an iAero. I'll notice, for example, coming to a complete stop and when I get going again the initial data point is ~2000 watts.
mullerrj
Re: Getting TrainingPeaks/WKO to use DFPM power
Post by mullerrj »
When I uploaded my iBike file into Training Peaks it showed my DFPM power, not the iBike power. Did you check the box in the iBike 3 Software that says, "View DFPM"? I did that before I saved the file, and by doing that I think it saved the DFPM Power instead of iBke Power. I use a Power Tap SL 2.4+.
All iBike files recorded with a DFPM have both iBike and DFPM data included in them. You'll see each column labeled in the ride file.
To see your DFPM data in WKO+, copy and paste the DFPM power data over the iBike power data. Save it as a different file so you can have the original, just in case!
SRM data tends to be spikey but there may be something wrong. Please send us a ride file with this data.
kylef
Post by kylef »
just to follow up on my own question, more recent versions of WKO will read from the DFPM column instead of the Power column. Problem solved!
