Stages PM paired with newton and cadence
richwagmn
Post by richwagmn »
I've got a stages PM paired with my Newton+. My understanding is that the Stages PM also sends cadence. However, I also have a speed/cadence sensor paired with the Newton+
Which cadence sensor will be used? The reason I ask, is that the cadence display now seems a bit flakey. At times cadence will switch to a display that says somethign 0_37 or something. It never drops Power and bullseye is always on.
Are two cadence sensors confusing the Newton+?
Re: Stages PM paired with newton and cadence
You are enjoying one of the advanced features of the Newton+; when you have a DFPM, your Newton will display, in real time, your measured drag coefficient (CdA).
Your drag coefficient is 0.37 (0_37). The bottom window alternates between cadence and CdA.
If you don't want to see continuous CdA, enter Setup, scroll to the "CdA On" screen, click the center button to make "on" flash, use the up arrow to select "off", then click the center button to accept. Exit setup.
richwagmn
Post by richwagmn »
Oh super! Thanks for the clarification.
