VeloTrack doesn't record correctly
blp
Post by blp »
Over the last little while the VeloTracker has not recorded the whole ride. The latest, yesterday, recorded 3:29:28, but total ride time of 00:08:42. Of a 45 Km ride only 3.2 Km. was recorded. The GPS shows accurate track for about 4-5 minutes, then jumps 15 Km, records a bit again then stops altogether.
Is it the app or iPhone GPS?
Re: VeloTrack doesn't record correctly
App is unchanged and there have been no other reports of troubles.
blp
Post by blp »
I will delete the app and re-install.
DaveG
Post by DaveG »
This has happened to me on a regular basis - for whatever reason, it just stops in the early part of the ride. Today I rode about 30 miles, and VeloTrack quit after 6 miles, and it was on a loop I regularly ride and it has recorded correctly many times.
I have the latest VeloTrack and Isaac releases, and latest iphone OS software. FWIW, I intend to reboot my iPhone 8 before each ride and see if that helps.
It sounds like you are using iOS version.
In the settings page, make sure Auto Pause is turned off.
