Newbie with question regarding wind compensation
Korny510
Post by Korny510 »
Hi
I just installed and setup my powerpod.
I used profile 1 as I used the supplied mount.
After the calibration run the wind compensation was set to 1.7!?
I did quite a perfect go and return ride. But stopped about 300 m later, can I anyways use this to recalibrate?
Thanks from Germany,
Andreas
Best regards,
Andreas
Re: Newbie with question regarding wind compensation
Please post a ride file and we will check things.
Korny510
Post by Korny510 »
Hi John.
attached is a file recorded yesterday after the calibration ride.
FYI is tried the check calibration feature and the wind scaling was set to 1.377.
Thanks for your efforts.
I will now calibrate my PowerPod for my second bike.
iBike_07_24_2016_1142_29_km.ibr
First ride after calibration
(216.14 KiB) Downloaded 277 times
Best regards,
Andreas
The ride file you posted is really close; the optimized profile is attached. I got a wind scaling factor of 1.581 from the Analyze/Check Calibration feature.
Team Edition.ibp
(570 Bytes) Downloaded 312 times
Korny510
Post by Korny510 »
Hi John.
Thanks so much!
I'll try this profile tomorrow, when the weather will be better than today.
Best regards,
Andreas
