26 mm combo mount
26 mm combo mount
I have two standard bar mounts as well as the out-front mount for my PowerPod. But I have 4 bikes... The remaining one is my poor weather/commuter road bike which is becoming increasingly vintage - aka compatibility issues start to show.... It's a '92 alu-frame with a 26 mm handlebar. I would really like to be able to attach the PowerPod and the Garmin 820 securely. Even the Garmin sits rather unstable with its flimpsy O-ring fixed round plastic mount. Do you know of any 26 mm K-edge style out-front combo mount that is stable enough?
Re: 26 mm combo mount
Go to your local bike shop and see if they have any plastic rings that adapt 31 mounts to 26mm handlebars. If they do this will work just fine. Just make sure to firmly squeeze the mount on to the adapter ring.
