Calibration check after encounter with dog during cal run
sjakiepiet
Post by sjakiepiet »
Hi!
I'm a new user and did my O&B calibration run. All went well, except for a unexpected encounter with a loose dog that forced me to slow down below 10mph. I did not need to stop completely though. I just wanted to double check that the calibration still is valid or not?
Please find attached the calride and a short trip immediately afterwards. I have the gut feeling that all is well (power numbers "feel" quite close to my Taxc Vortex Smart trainer), just wanted some confirmation that indeed I am good to go!
Also, as a side question, is it possible to re-analyze the ride file PRIOR to my first cal ride (basically the part where I rode out to the starting point of the O&B ride) with the calibrated settings? The power values are WAY off there mainly because of the tilt that was not corrected.
Thanks very much!
iBike_04_30_2017_0759_4_Miles.ibr
ride BEFORE O&B calibration
(44.49 KiB) Downloaded 210 times
iBike_04_30_2017_0824_12_Miles.ibr
ride after O&B calibration
(131.65 KiB) Downloaded 234 times
iBike_04_30_2017_0813_3_Miles_CalRide.ibr
O&B calibration ride
(41.64 KiB) Downloaded 220 times
Re: Calibration check after encounter with dog during cal ru
Things look fine!
Use the "Analyze/Analyze Route" function to fix your pre-cal ride.
