Velocomp Garmin Powerpod handlebar mount trouble
Speedyg
Post by Speedyg »
Have just purchased the V-comp Garmin/Powerpod combo mount and tightening the Powered as much as possible with the existing Powered thumbscrew it just isn't totally tight allowing for some changes in skew if there's a big bump in the ride. What to do??
flahutewannabe
Re: Velocomp Garmin Powerpod handlebar mount trouble
Post by flahutewannabe »
I once inadvertently put the bolt in from the wrong side (into the brass bushing first rather than through the plastic side into the brass) and had the same thing. You might confirm you're inserting the thumbscrew from the correct side.
Even with the correct side, it does take some cranking down to get it tight.
Speedyg wrote: Mon Jul 09, 2018 2:33 pm Have just purchased the V-comp Garmin/Powerpod combo mount and tightening the Powered as much as possible with the existing Powered thumbscrew it just isn't totally tight allowing for some changes in skew if there's a big bump in the ride. What to do??
Please email technicalsupport@velocomp.com There is an easy fix Tom will tell you how to do.
Speedyg
Post by Speedyg »
Inserted screw from the other side and it's fine!
