Question about calibration after handlebar position change
mejulie69
Post by mejulie69 »
I've just changed the position of my handlebars and whilst I have tried to keep the same angle on the PP, inevitably the angle will have changed a tiny bit. Do I need to force a recalibration or will it recalibrate itself? If it recallibrates itself, does it keep the new calibration or does it revert back to original calibration each time?
Wayne77
Re: Question about calibration after handlebar position change
Post by Wayne77 »
I'm interested in an answer to this question as well. I would LOVE to know if there is a way to correct for a tilt that changed without having to do another calibration ride. Why? Because I have painstakingly used a powermeter to tweak the settings of the current profile and I don't want to start all over with a new one.
If the only thing that has changed about your setup is the angle of your PP, you do NOT have to perform a new calibration. PP will figure things out, and at the end of the ride it will memorize the corrected angle.
