Wind is off
Arnoldus
Wind is off
Post by Arnoldus »
I have some trouble getting the wind offset right. My watts are way to low and if I look at analyze wind I can see the wind offset needs to by corrected. I then change this to a avg ground wind of zero and press accept. Will this store the adjusted setting on the powerpod device or do I need to do something else to prevent the wind settings to be off in future rides?
Re: Wind is off
You need to do a new calibration ride.
Please post a .ibr ride file and I will take a look.
If you use the Analyze Wind function that does not make adjustments in your PP profile.
