Powerpod or virtual power
Yosser70
Post by Yosser70 »
I'm setting up to do some indoor training on a dumb trainer. Would I be better using virtual power on say trainerroad or use my Powerpod (only reason I ask is my trainer isn't on the list in Iassc, so can only gey a close approximate of power). I'm guessing the PP would be better but also wondering how people find their indoor and outdoor numbers compare when using the PP. I like to use the fitness/freshness charts so having the data from indoors and out at least close is important.
Re: Powerpod or virtual power
Either will be fine, though PP will save your training files for later use.
Yosser70
Post by Yosser70 »
OK, thanks for that. On the trainer front, is adding watts to another profile ok to get it closer to mine or is there a way of adding the correct profile?
You can customize a profile in the Edit Training Settings menu of Isaac.
