"Recalibrate" and keep existing sensor pairings?
Will
Post by Will »
I think I have accidentally bumped my device and changed the tilt because it shows zero watts for the first ~5 minutes of my ride before doing its internal recalibration. Otherwise, it's working perfectly well. Is there a way to get the device to do an out-and-back calibration without completely resetting my profile and having to pair my speed, cadence, and HR sensors again? Would I lose much accuracy if I extract the profile from a recent ride file where it has self-corrected after the initial 5-minute problem?
Re: "Recalibrate" and keep existing sensor pairings?
After a few minutes your device will recalibrate itself. At the end of the ride it will remember the recalibration.
As long as you don't move the device again between rides, your next ride should be good from the very start.
