PP Mount between clip on aero bars
warbs
Post by warbs »
Hello,
I'm thinking of mounting my PP dead centre out in front of the stem using a garmin/gopro stem mount.
Firstly, has any got experience of this kind of mount, does it effect accuracy compared to being clamped directly to the handbars? I'm thinking about vibration interfering with the readings.
Secondly, If I add and remove clip on aero bars, about 15cm apart, will that likely effect readings, or will I need to calibrate each time I add or remove the bars?
cheers
Chris
Re: PP Mount between clip on aero bars
You're OK to attach with Garmin/GoPro mount as you suggest. There will be no degradation of performance, as long as your front mount is made from machined aluminum.
I think you won't be adversely affected by aero bars.
warbs
Post by warbs »
Thanks for the response...I'll give it a try
Cheers
Chris
