iBike locks up, order of Set Up
MultiRider
Post by MultiRider »
My Gen 3 has locked up several times in the Set Up mode. I think they all occurred when on the Profile screen, but not 100% certain of that. I'm on 3.08. The iBike just locks -- can't change the value on the screen, can't get out of Set Up, will not turn itself off even after 2 hours and being disconnected from the mount and just sitting on my desk post-ride. The only way to get it to respond is to remove the battery. Which erases the ride data. Bummer, that.
Perhaps the order of the parameters in the Set Up menu could be rearranged. I think Trainer, Wind Offset, and Profile should be next to each other because those are the most likely to change when starting a new ride and turning it on for the first time. And Wireless Config should be next to them in case a person wanted to swap between a wired and wireless mount. Perhaps Weight should be there. Recording Interval could be in the same area. I often find myself punching the right arrow over and over and over and over again to find what I'm looking for. And I look for the same few things each time.
Jim Mason
Re: iBike locks up, order of Set Up
Remove the battery, insert it backwards for a moment, then reinsert normally. This will do a hard reset and hopefully correct your problems.
If you do a Trip Reset at the end of each ride your data will be stored and safe, even if you remove the battery.
