I installed my iBike Pro on handlebars initially, did all calibrations as per instruction and did couple of rides, everything seemed to be perfect.
Then I got my TT handlebars, ordered handlebar eXtender as it was advised in manual, installed everything,
having iBike above the handlebars trying to avoid anything which would prevent air from flowing in. Did a ride and already during a ride noticed that power measured is much lower then durning previous rides. After downloading data I saw, that wind was measured being always from behind although I did the same route back and fourth and on one way there was a pretty strong wind against me.
Decided to change location of iBike, now installing it under the bars, although I can not monitor numbers on the screen, I decided to give it a try, did a short ride and results were the same, wind registered being only from behind although I did a circle of 10 miles.
I did calibrated tilt and wind offset after every repositioning.
Finally I removed TT handlebars and installed iBike back same way it was installed initially. Just came back from the ride and results are not good, there has been sections with pretty strong head wind, but it was registered as almost no ground wind.
Does anybody have an idea, what should I try next?
P.S. Because of this trouble my power numbers are very low, which demotivates me a lot
