Isaac 2.0.0 forces x-axis to "time"
texmurphy
Post by texmurphy »
If I change the Show x-axis from Time to Dist, on next load of Isaac 2.0.0 it reverts back to "Time".
Prior versions remembered the x-axis preference.
wlv31
Re: Isaac 2.0.0 forces x-axis to "time"
Post by wlv31 »
I noted this also. Hopefully it will be changed back in the next sw update?
travispape
Site Admin
Post by travispape »
texmurphy wrote:If I change the Show x-axis from Time to Dist, on next load of Isaac 2.0.0 it reverts back to "Time".
Yep, found the bug that causes this and will fix it soon. It is the same issue with metric units reverting to english, which will be fixed too.
Look for a new build in the next few days.
Zoltan
Post by Zoltan »
travispape wrote: It is the same issue with metric units reverting to english, which will be fixed too.
Do you mean you are about to fix all the instances of sticking to english units? Like in all the menu items of Analyze menu column or in Tools/Effort speed? Or in Edit profiles and Set Display Units. and in Download Coast Downs & Cal. Rides ?
I've been waiting for it for a pretty long while, see http://www.ibikeforum.com/viewtopic.php ... 26&p=14009
Thanks for it.
