A question on tilt
cjonbike
A question on tilt
Post by cjonbike »
I ride a recumbent so I can not see the iBike while I am riding. I have a good profile. If I do not care what the numbers read while I am riding, can I go out and ride without doing a Tilt Calibration and get good data when I get back and do the Post Processing on the computer?
Thank you in advance for all input
Chris
coachboyd
Re: A question on tilt
Post by coachboyd »
Yes, the software will correct the tilt afterwards. If you don't see the unit at all on the bike, then this is going to be the best option.
Just make sure that the front of the iBike has a good clean view of the wind (nothing in front that could cause an air wake or block wind from entering the unit)
cjonbike
Post by cjonbike »
Coach Boyd
Thanks so much for your help.
Chris
coachboyd
Post by coachboyd »
No problem, and a question for you.
What is your cda on the recumbent?
cjonbike
Post by cjonbike »
I ride a trike and the CDA is .456
Thanks again
Chris
