Problem usind second bike
Korny510
Post by Korny510 »
Well, i just tried to add my second bike, but having some problems with Isaac software and calibration / link to bike.
I have different Sensors for speed and cadence on each bike, I activated profile 2 (using a front-out mount for this bike) and did a calibration run.
When downloading the data Isaac seems to link it to bike no. 1 indstead of no. 2?!
Second the calibration run was not recorded properly as the power is missing, so I can't check the calibration. I did a ride with similar start and end point just to check the calibration afterwards :?
How can I force my PowerPod to select the correct profile when changing bikes?
Best regards,
Andreas
Re: Problem usind second bike
After setting your Profile to your second bike, and before starting your calibration ride, did you do a sensor pairing? And if you did a pairing, did you do so in a location where your PP would not "accidentally" pick up your first bike?
It sounds like your PP is not paired to your second bike.
Korny510
Post by Korny510 »
Hi John.
Yes, I did a pairing where no other sensors should be picked up.
I could solve the problem by connecting the PP again, selecting the profile and and pair again. Now the PP picked the correct sensors and tomorrow I'll do another calibration ride.
Thanks for the great support!
Best regards,
Andreas
