Switch Profile from #4 to #3?
kq6up
Post by kq6up »
If I just edit the name of a profile from #4 to #3, will it just become a normal profile, or do I have to set up from scratch for profile 3?
Chris Maness
Re: Switch Profile from #4 to #3?
You have to do four things:
1) Switch the profile number in Edit/Edit Profiles
2) Enter the parameters for your new profile, either in Edit Profiles or using Device/Setup
3) Pair sensors to your new profile
4) Do a cal ride for the new profile
kq6up
Post by kq6up »
I was able to get it to switch without a cal ride. The same sensors, and I wanted to use all the same parameters from my CdA profile (#4) to #3.
1. I edited the number.
2. I used the "Set Active Profile" feature to select #3.
3. Sent the edited profile.
4. Extracted profile from device -- "viola!" the correct profile in #3.
Regards,
Chris Maness
Yes, that will work!
Note that you have the same sensor IDs in two profiles. Automatic Profile Selection won't work properly in this condition; you will have to switch profiles manually.
kq6up
Post by kq6up »
I have had to do that most of the time anyhow. While I am thinking about it, can you guys put the ability to select trainer mode in PowerHouse?
Chris Maness
This actually would be a significant effort (new commands back and forth from device to app).
